[Lisp #389] DBLK : Specified Block (Global)
  • DBLK
This tool allows you toใ€€delete all instances of a specific block throughout the entire drawing by entering its name.
  • Global Deletion: It searches the entire drawing for blocks matching the provided name and erases them all at once.
  • Name-Based: You must specify the exact name of the block you wish to remove.
3/ How to Use:
  1. Type DBLK in the command line and press Enter.
  2. Type the name of the block you want toใ€€delete and press Enter.
  3. All blocks with that name are immediately removed from the drawing.
