[Lisp #336] 6LEA : Draw Split Hex Leader
  • 6LEA
This tool draws a leader line that terminates in a hexagon symbol containing two lines of text.
  • Symbol Creation: Automates the creation of a hexagonal leader annotation often used for revision clouds, part numbers, or specific engineering notes.
  • Two-Line Text: Allows inputting two separate lines of text (upper and lower) within the hexagon.
  • Dynamic Scaling: The size of the arrow, text, and hexagon is controlled by the DIMSCALE and DIMTXT variables. Changing these settings will resize the entire annotation.
  • Input: Requires three points (leader start, knee, end/symbol location) and the text content for the top and bottom lines.
  1. Type 6lea in the command line and press Enter.
  2. Click the Leader Start Point (PT1).
  3. Click the Leader Knee Point (PT2).
  4. Click the Symbol Location Point (PT3).
  5. Type the Upper Text content and press Enter.
  6. Type the Lower Text content and press Enter.
  7. The leader with the hexagonal symbol and text is drawn.
