[Lisp #319] AH : Draw Vent Pattern
  • AH
This tool draws an array of ventilation slots (air holes), often used in electrical enclosures or machinery panels.
  • Slot Generation: Creates elongated slots with rounded ends.
  • Array Function: Automatically copies the slots upwards to create a ventilation grille pattern.
  • Shape Adaptation: Depending on the quantity and dimensions, the shape representation might simplify (e.g., to a simple rectangle or semi-circle for large counts/small scales).
  • Input: Requires a start point, slot width, slot height, top fillet radius, total count (vertical array), and pitch (vertical distance between slots).
  1. Type ah in the command line and press Enter.
  2. Click the Start Point (PT1).
  3. Enter the Slot Width (Horizontal dimension).
  4. Enter the Slot Height (Vertical dimension).
  5. Enter the Top Fillet Radius.
  6. Enter the Total Count of slots to copy upwards.
  7. Enter the Pitch Distance (Vertical spacing between slots, e.g., 30).
  8. The ventilation hole pattern is drawn.
