[Lisp #318] DT2 : Create Text (Ratio Spacing)
  • DT2
This tool allows you to create multiple lines of text with specified, consistent spacing between them.
  • Structured Text: Instead of manual placement, you define the line spacing once and enter text line by line.
  • Spacing Control: You input a multiplier for line spacing. Entering 2 creates a gap equal to the text height.
  • Input: Requires a start point, a line spacing value, and then the text content for each line.
  1. Type dt2 in the command line and press Enter.
  2. Click the Start Point (PT1) for the first line of text.
  3. Enter the Line Spacing Value (e.g., 2 for double spacing based on text height).
  4. Type the Text Content and press Enter.
  5. Repeat step 4 to add more lines.
  6. Press Esc to finish and exit the command.
