[Lisp #317] CM : Draw Center Mark
  • CM1 : Draw Center Mark Top Left
  • CM2 : Draw Center Mark Top Right
  • CM3 : Draw Center Mark Bottom Right
  • CM4 : Draw Center Mark Top Left
  • CM45 : Draw Center Mark Top Right, Bottom Left
  • CM135 : Draw Center Mark Top Left, Bottom Right
This tool automatically draws various types of center marks onใ€€selected circles.
  • Variety: Provides commands for different center mark styles (e.g., standard crosses, rotated crosses at 45 or 135 degrees).
  • Combination: You can apply multiple commands to the same circle to create complex center marks (e.g., applying CM1 and CM3 creates a CM135 style).
  • Input: Simply type the desired command (e.g., CM45) and click on an existing circle.
  1. Type the desired command (e.g., cm45) in the command line and press Enter.
  2. Select an existing Circle.
  3. The specified center mark is drawn on the circle.
    • Tip: To create a combined mark like a starburst, use cm1 then cm3 (or cm2 then cm4) on the same circle.
