[Lisp #313] PCOM / MCOM: Add / Remove Thousands Separator
  • PCOM : Add Thousands Separator
  • MCOM : Remove Thousands Separator
This tool provides a quick way to format numbers in text objects by adding or removing the thousands separator (comma).
  • PCOM: Adds commas to numbers (e.g., changes "1000" to "1,000").
  • MCOM: Removes commas from numbers (e.g., changes "1,000" to "1000").
  • Batch Processing: Can process multiple text objects at once.
  1. To Add Commas:
    • Type pcom in the command line and press Enter.
    • Select the Text Objects containing numbers.
    • The numbers are automatically formatted with commas.
  2. To Remove Commas:
    • Type mcom in the command line and press Enter.
    • Select the Text Objects containing numbers with commas.
    • The commas are removed from the numbers.
