[Lisp #307] 454C : Draw 4 Diagonal Circles Outside Rect
  • 454C
This tool draws four circles inside a rectangle (or rounded rectangle), positioned at 45-degree angles from the corners.
  • Angular Layout: Specifically designed to place mounting holes or features along the diagonal axes of the corners.
  • Input: Requires defining the rectangle (two points), offsets from the corner to the circle center, and the circle diameter.
  • Auto-Layer: Automatically creates the center layer if missing.
  1. Type 454c in the command line and press Enter.
  2. Click the First Corner Point (PT1) of the rectangle.
  3. Click the Second Corner Point (PT2).
  4. Enter the Horizontal & Vertical Offset from the corner to the circle center (e.g., 20).
  5. Enter the Circle Diameter.
  6. Four circles (with center lines) are drawn at 45-degree positions relative to the corners.
