[Lisp #282] BFLG : Draw Double Flanged Pipe
  • BFLG
This tool automatically draws flanges on both ends of a pipe or duct segment based on user inputs.
  • Standardization: Generates standard flange shapes according to the sequence of inputs provided.
  • Input: Requires a start point, a direction point, and a series of sequential inputs (as prompted by the numbered order in the tool's diagram) to define dimensions.
  1. Type bflg in the command line and press Enter.
  2. Click the Start Point (PT1).
  3. Click the Direction Point (PT2).
  4. Enter the required values in the order prompted (typically defined by the diagram in the post, e.g., flange diameter, thickness, etc.).
  5. The double flange drawing is generated automatically.
