[Lisp #280] CROCUT : Cross-Cut Rectangle
  • CROCUT
This tool cuts a cross shape out of a rectangle based on user-defined horizontal and vertical dimensions.
  • Operation: It trims the rectangle's sides towards the center, creating a cross-like opening or cut.
  • Input: Requires the two corner points of the rectangle, followed by the horizontal cut width and vertical cut height.
  1. Type crocut in the command line and press Enter.
  2. Click the First Corner Point (PT1).
  3. Click the Opposite Corner Point (PT2).
  4. Enter the Horizontal Cut Value (e.g., 7).
  5. Enter the Vertical Cut Value (e.g., 14).
  6. The rectangle is modified into a cross-cut shape based on the input values.
