[Lisp #254] DIMO : Reset Dim Value
  • DIMO
This tool restores a dimension's text value to its original measured value, removing any manual overrides or edits.
  • Utility: Useful for quickly resetting dimensions that have been manually modified with text like <>.
  • Automation: Instantly revertsใ€€selected dimension objects to their true geometry-based value.
  1. Type dimo in the command line and press Enter.
  2. Select the Dimension object you want to reset.
  3. The dimension text automatically reverts to the original calculated value.
