[Lisp #248] SRING2 : Draw Int. Snap Ring
  • SRING2
This tool automatically draws a snap ring (retaining ring) groove inside a bore (hole) based on the hole's diameter.
  • Automation: Generates the standard groove geometry for an internal snap ring.
  • Standards: Automaticallyใ€€selects the correct groove dimensions matching the hole diameter defined by the user's input points.
  1. Type sring2 in the command line and press Enter.
  2. Click Point 1 (One side of the hole diameter).
  3. Click Point 2 (The opposite side of the hole diameter, defining the width).
  4. Click Point 3 (The direction where the groove should be drawn).
  5. The correct internal snap ring groove is drawn automatically.
