[Lisp #232] ENASA4 : Draw 4 Tapped Holes in Rectangle
  • ENASA4
This tool automatically draws a rectangle with four internal thread (tap) top-views positioned at each corner.
  • Automation: Generates a base plate (rectangle) and simultaneously places four tapped holes based on defined offsets.
  • Inputs: Requires defining the rectangle dimensions, offsets for the hole positions, and the metric thread size.
  1. Type enasa4 in the command line and press Enter.
  2. Click the Bottom-Left Start Point.
  3. Enter the Rectangle Horizontal Length.
  4. Enter the Rectangle Vertical Length.
  5. Enter the Horizontal Offset (distance from the edge to the first hole center).
  6. Enter the Vertical Offset (distance from the edge to the first hole center).
  7. Enter the Metric Thread Size (number only, e.g., 10 for M10).
