[Lisp #226] SLBK : Draw Sleeve Block
  • SLBK
This tool automatically draws a sleeve block for mold design, including the front view with counterbore holes and the side view block, while applying dimensions simultaneously.
  • Automation: Generates the complete 2D geometry of the sleeve block and its side view based on user inputs.
  • Inputs: Requires defining dimensions, screw specifications, and hole patterns.
  1. Type slbk in the command line and press Enter.
  2. Click the Start Point.
  3. Enter the Horizontal Length.
  4. Enter the Vertical Length.
  5. Enter the Metric Screw Standard for counterbore holes (number only, e.g., 8 for M8).
  6. Enter the Number of Counterbore Holes.
  7. Enter the Distance to First Hole Center.
  8. Enter the Side View Block Width.
