Utility Archive ยท 2026.02.25
[Lisp #71] ST2 : Quick Stretch
  • ST2
This tool is a "revolutionary" improvement over the standard STRETCH command, designed to extend a rectangle's side or a line with minimal clicks.
  • Efficiency : Standard STRETCH often requires up to 7 clicks (Command > Crossใ€€Select > Enter > Base Point > Target Point). ST2 reduces this to just 2 clicks or inputs.
  • Polyline Handling : If applied to a Polyline, the tool will automatically explode it first; you simply re-select the line to extend it.
  1. Type ST2 in the command line and press Enter.
  2. Select the Line (side of the rectangle) you want to extend.
  3. Specify the Direction and Distance:
  • Move your mouse in the desired direction and Click a point on the screen.
  • OR move your mouse in the direction, type the Distance Value, and press Enter.
4. The line (or side) is extended immediately.
