Utility Archive ยท 2026.02.25
[Lisp #69] AAR : Auto Linear Array
  • AAR
This tool allows you to perform a Linear Array (Copy) of objects in any direction.
  • Flexible Direction : Unlike standard arrays that might be restricted to X/Y axes or require specific settings, this tool lets you define the array direction simply by clicking points on the screen.
  • Quick Linear Copy : Easily create a single row of copies spaced at a specific interval in any chosen direction.
  1. Type AAR in the command line and press Enter.
  2. Select the Objects to array and press Enter.
  3. Click a Base Point on the screen.
  4. Click a Direction Point to define the angle/direction of the array.
  5. Enter the Distance (Interval) between objects.
  6. Enter the Total Quantity of objects.
  7. The objects are arrayed in a single line along the specified direction.
