Utility Archive ยท 2026.02.24
[Lisp #61] DTOD : Override Dim with Measure
  • DTOD
This tool allows you to measure the distance between two points on your drawing and instantly apply that measured value to an existing dimension object.
  • Value Override : Useful when you need a dimension text to reflect a specific physical distance measured elsewhere, or to force a value based on a measurement.
  • Format : The number format (decimal places) respects your current units settings (adjustable via the UNITS command).
  1. Type DTOD in the command line and press Enter.
  2. Click the First Point to measure from.
  3. Click the Second Point to measure to.
  • The distance between these two points is calculated.
  1. Select the Dimension Object you want to.
  • The dimension text changes to match the measured distance.
  • Note: If youใ€€select a non-dimension object, the tool will prompt you again until a valid dimension isใ€€selected.
