Utility Archive ยท 2026.02.24
[Lisp #60] ACOL : Auto Column Grid
  • ACOL
This tool is an interactive utility for drawing Column Centerlines (Grids) and Column Numbers (Bubbles), which is typically the first step in architectural drafting.
  • Interactive Mode : Guides you through inputs for building size, intervals, and numbering.
  • Auto-Dimensioning : Automatically places dimensions along with the grid lines and bubbles.
  • Flexible Numbering : Supports numeric (0, 1, 2...) for horizontal grids and alphabetic (A, B, C...) for vertical grids.
  1. Type ACโ€‹OL in the command line and press Enter.
  2. Enter the Total Width and Total Height of the building.
  3. Click the Bottom-Left Corner (Start Point).
  4. Enter the Diameter for the column number circles (bubbles).
  5. Horizontal Grid Setup:
  • Enter the Start Number (e.g., 0 or 1).
  • Enter the distance to the Next Column repeatedly.
  • Type 0 and press Enter to finish horizontal lines.
  1. Vertical Grid Setup:
  • Enter the Start Character (e.g., A).
  • Type 0 and press Enter to finish vertical lines.
7. The grid, bubbles, and dimensions are drawn instantly.
