Utility Archive ยท 2026.02.13
[Lisp #49] TT : Match Text Content
  • TT
This tool allows you to easily copy the content of one text object and apply it to another text object.
  • Quick Text Swap : Instead of retyping or manually copy-pasting text strings, you can simply click the source text and then the destination text to it immediately.
  • Text Transfer : Transfers the string value from a "Source" to a "Target" instantly.
  1. Type TT in the command line and press Enter.
  2. Select the Source Text object (the text you want to copy).
  3. Select the Target Text object (the text you want to change).
  4. The target text is immediatelyd to match the source text.
