Utility Archive ยท 2026.02.13
[Lisp #47] ADIM : Auto Dimension
  • ADIM
This tool is an upgraded version of the standard QDIM command, designed to handle multiple dimension types intelligently.
  • All-in-One Logic : Unlike QDIM which focuses on horizontal/vertical/radius, ADIM automatically detects the object type and orientation to apply the correct dimension.
  • Supported Types : Supports Horizontal, Vertical, Aligned (sloped/inclined), and Diameter dimensions within a single command.
  1. Type ADIM in the command line and press Enter.
  2. Select an object (Line or Circle).
  • If Line: It detects if it is horizontal, vertical, or inclined and applies the corresponding linear dimension.
  • If Circle: It applies a diameter dimension.
  1. The appropriate dimension is created automatically.
