Utility Archive ยท 2026.02.13
[Lisp #40] REVM : Draw Revision Mark
  • REVM
This tool allows you to easily place a Revision Mark (Delta symbol with a number/letter) on your drawing.
  • Standard Symbol : Draws a triangle with the revision character centered inside.
  • Auto-Scaling : The text size automatically adjusts to match your current dimension text settings.
  1. Type REVM in the command line and press Enter.
  2. Click theใ€€Insertion Point where you want the revision mark to appear.
  3. Enter the Revision Character (e.g., 1, A, etc.) and press Enter.
  4. The triangle mark with the centered text is drawn immediately.
