Utility Archive ยท 2026.02.13
[Lisp #32] C0 / R0 : Quick Chamfer / Quick Fillet
  • C0 ~ C50 (Chamfer)
  • R0 ~ R50 (Fillet)
This tool provides immediate shortcuts for Chamfer and Fillet commands with pre-set values ranging from 0 to 50.
  • Instant Value Setting : Instead of typing CHAMFER > D > 10 > 10 > Enter, you can simply type C10.
  • Wide Range : Supports integer values from 0 to 50 for both Chamfer (C) and Fillet (R).
  • Zero Value Utility : C0 and R0 act as a "corner connect" tool (Trim/Extend to corner with 0 radius/distance).
  1. For Chamfer : Type C followed by the desired distance (e.g., C1, C5, C50).
  • Note: Applies equal distance for both sides (Dist1 = Dist2).
  1. For Fillet : Type R followed by the desired radius (e.g., R1, R10, R50).
  2. Select the First Object (Line).
  3. Select the Second Object (Line).
  4. The corner is immediately modified with the specified chamfer distance or fillet radius.
