Utility Archive · 2026.02.13
[Lisp #29] NOTCH : Notch Rectangle Corner
  • NOTCH
This tool allows you to easily cut out (notch) the corner of a rectangle based on specific X and Y dimensions.
  • Precise Cutting : You input the width and height of the area to be removed from the corner.
  • Corner Versatility : Works on any corner of a rectangle.
  1. Type NOTCH in the command line and press Enter.
  2. Select the Corner Point of the rectangle you want to cut.
  3. Click roughly towards the Inside (center) of the rectangle to define the direction.
  4. Enter the Horizontal Distance (Width) to cut.
  5. Enter the Vertical Distance (Height) to cut.
  6. The selected corner is immediately notched out according to your inputs.
