Utility Archive · 2026.02.12
[Lisp #20] XBOX : Draw Rect with X
  • XBOX
This tool draws a rectangle with an X-Cross (diagonal lines) inside it in a single step.
  • All-in-One : Combines drawing the boundary box and the diagonal cross lines into one command.
  • Flexible Input : Offers two methods for defining the box dimensions (Two Points or Dimensions).
  • Layer Aware : Objects are created on the Current Layer.
  1. Type XBOX in the command line and press Enter.
  2. Choose a drawing method :
  • Option 1 (Two Points) : Click the start corner and the opposite corner.
  • Option 2 (Dimensions) : Click the bottom-left start point, then input (or click to define) the Width and Height.
  1. The rectangle and the X-cross are generated immediately.
