Utility Archive ยท 2026.02.12
[Lisp #16] HOM : Draw Shaft Keyseat
  • HOM
This tool automatically cuts a Keyseat (Keyway groove) into a shaft cross-section (Circle).
  • Multi-Directional : You can generate the keyseat in any direction (Top, Bottom, Left, Right, etc.) by simply clicking the desired side.
  • Interactive : Quickly applies standard keyway dimensions (Width and Depth) to an existing circle.
  1. Type HOM in the command line and press Enter.
  2. Select the Circle (Shaft cross-section).
  3. Click a point to define the Direction of the keyseat.
  4. Enter the Width of the keyseat.
  5. Enter the Depth of the keyseat.
  6. The keyseat geometry is automatically trimmed and generated.
Note : For best results, ensure the circle is zoomed in sufficiently on the screen before running the command. If the view is too far out, the objectใ€€selection might not register correctly.
