Utility Archive ยท 2026.02.12
[Lisp #13] TR2 : Quick Trim
  • TR2
This tool allows for immediate trimming without the initial step ofใ€€selecting cutting edges.
  • Streamlined Workflow : Standard TRIM commands often require you to "Select Cutting Edges" > "Enter" > "Select Object to Trim". With TR2, you simply run the command and start trimming immediately.
  • Auto-Boundary : It treats all visible objects on the screen as potential cutting edges automatically (similar to the "Quick Trim" or "Trim > Enter" workflow in other CAD software).
  1. Type TR2 in the command line and press Enter.
  2. Immediately click on the objects (or segments) you want to trim.
  3. The segments are trimmed instantly based on the nearest visible boundaries.
  4. Press ESC to finish.
Note: This command only calculates trimming boundaries based on objects currently visible on the screen.
