Utility Archive ยท 2026.02.11
[Lisp #6] SHAFT : Draw Shaft
  • SHAFT
This tool allows you to interactively draw mechanical Shafts with ease.
  • Interactive Design : Simply input the diameter and length for each segment section by section.
  • Auto-Centerline : Automatically generates the central axis line across the entire shaft upon completion.
  • Smart Sizing : The centerline length automatically adjusts to fit the total shaft size.
  • Auto-Layering : Automatically creates and utilizes the CENTER layer.
  1. Type SHAFT in the command line and press Enter.
  2. Specify the Start Point (Center of the left end).
  3. Enter the Diameter of the first segment.
  4. Enter the Length of the first segment.
  5. Repeat steps 3 and 4 for subsequent segments.
  6. To finish, enter 0 when asked for the Diameter. The tool will draw the final centerline and exit.
