[Lisp #393] SPT : Extract Spline Vertex Coordinates & Draw Circles
  • SPT
This tool extracts the vertex coordinates (fit points) of a selected spline and automatically draws a circle at each vertex.
  • Coordinate Extraction: The X, Y, and Z coordinates for each fit point are displayed in the command history.
  • Visual Markers: Small circles are drawn at every vertex to visually identify the fit points on the drawing.
3/ How to Use:
  1. Type spt in the command line and press Enter.
  2. Select the Spline Object you want to analyze.
  3. Circles will be drawn at each vertex, and the coordinate list will be printed in the command window.
    • Tip: Press F2 to open the text window and check the coordinate data.
