[Lisp #392] DIMMG : Merge Linear Dimensions
  • DIMMG
This tool merges multiple separate linear dimensions into a single combined dimension.
  • Merge Function: It combines selected linear dimensions (Horizontal/Vertical only) into one continuous dimension line.
  • Important Caution: If the current dimension style settings (such as DIMSCALE) differ from the original dimensions, the arrow size and text height of the merged dimension may change to match the current settings.
3/ How to Use:
  1. Type DIMMG in the command line and press Enter.
  2. Click two points to create a Crossing Window over the dimensions you want to merge.
  3. Press Enter.
  4. The selected dimensions are combined into a single dimension.
