						CTB file format for printing (How to print as color or black/white ?)					 |
| Plot environment ; - How to print as color or black/white ? - How to print with pen width ? CADian supports CTB file , 'color/width map' tab function , like AutoCAD. How to use CTB file to define the Pen width at CADian ? 1. Execute PRINT(or, plot) command. 2.  3. Select "MonoChrome.ctb" at [Print Style Table(Pen ssignments) of the upper area. (You can find that printing color is indicated as the black color) Icad.ctb ------------ Print in color. MonoChrome.ctb ------ Print in black & white.(Gray scale) 4. Select [Edit] button after select files 5. Select [Properties] tab 6. Select the color to change the pen width 7. Select line width at [Lineweight] * If you don't find the width you want, pls register the new width value after select [Edit Lineweight] at the right end and buttom end 8. Please try after change all of them |
